New wheels checklist
Hey guys, before you say search... I have! I just need everyones opinion just to make sure these new wheels will fit. Also, background information, I have not leveled the front end and this is a daily driver - no off roading. I would like to lift the H3 but there is no point in paying $2,500 for a lift kit when it will serve no purpose but for looks, so that is out of the question.
I have a H3x with 62,xxx on the stock tires and want to change the wheels out to Eagle Alloy Series 186 (1864-9966).
They are 18x9, 6 on 5.5 bolt pattern, offset of 2, and backspacing of 5.00". I used these 2 threads to try and figure out what tire size I needed
https://www.hummerforums.com/forum/h...x-31187/page2/
Tire size calculator
and have come to the conclusion that I want a bigger tire than the stock size to give it a meaner look so I think 315/65/18 (34.1"/12.4"/18) Nitto Terra Grappler or Goodyear Wranglers to wrap the new rims would do the job. My questions are:
- Will there be any rubbing?
- Will they fit with the offset and backspacing they have?
- Will I need an alignment after I install the new wheels?
- Any other suggestions?
if you don't do any offroading, the odds are slim, but there is a change at full lock. Make sure that the hub bore is big enough. the H3 has a 100mm hub. you back spacing will be fine, but they will still stick out a little since you are going from a 7.5" wheel to a 9" wheel. If all you are doing is wheels and tires there is no reason to get an alignment, but if you crank the t bars you will want one.
Gregg McGraw
02-16-2014 02:00 PM
hilljob26
09-26-2007 05:00 PM
diamondh2
01-11-2007 11:10 PM
