New Transmission Needed Already !!
I have a 2003 H2 with around 45K miles on it. During a recent trip, I had trouble getting the vehicle to shift from 1st to 2nd. It also would not go into 4th gear. The dealership tells me that the "2 / 4 Band" is burnt. They recommend replacing the transmission at the cost of $3K! While my regular warranty has expired, I was hoping that it would be covered elsewhere (e.g., 100K mile powertrain warranty, etc.) The dealership says no. Any input would be helpful.
RE: New Transmission Needed Already !!
did they tell you this after inspecting it, or over the phone? the same sort of thing happened to me but it was the ignition module.
as for the warranty, they only come with a 36K, 3 year warranty. anything past that would have to have been an extended warranty, purchased through GM or a third party.
bummer. sounds like you'll be getting a new tranny. at least it comes with a 12 month warranty. you may want to enquire about an extended warranty, but i don't know if they sell them once the factory warranty is expired.
i cant belive it too...i aslo have a 2003 hummer and it has less miles on it.....and guess what same problem....1st gear slips and overdrive dont work.....the speedo looks all wack out when im slowing down plus the trans temp get pass 200 almost going to 250.....what did you have to do to fix it ....the dealer is blaming it on me ...because i drop it .....theres no way in hell its because of that .......and i always baby my h2......this sucks....hahahahaha....let me know how you fixed yours.....thanks
if your temp is running hot on the tranny, you may want to check your coolant. the '03 radiators have had cases where the wall separating the engine and tranny coolant cracked and mixed coolant with tranny fluid. your coolant reservoir would look like it has brown pepto bismol in it if this happened. antifreeze in your tranny fluid is a bad thing.
I have a 2000 suburban, same kind of trouble...Needed new trans... Dealer rebuilt for $2k(12 Mo-12K warranty) or GM Factory for $2900 (5 yr - 50K warranty).. It was a no brainer...
On my H2 I just bought the Extended Warranty....
