Need a pass. rear door pocket or panel.
I have a 2003 h2 with the "ebony" (i.e. charcoal) colored interior panels. The rear passenger side door pocket has snapped off, and is M.I.A., so I am going to try to replace the pocket. Of course, GM does not sell just the pocket, so I would like to buy one from anyone that has a useable part. Or if anyone has a door panel in this color that is in good condition, I would be interested in purchasing it. Thanks
Derek
Derek
RE: Need a pass. rear door pocket or panel.
Hello Friend, It seems that this snapping off of the door pocket is a common problem.
I've noticed that as passengers step off the vehicle, occasionally their is a tendancy to tap with the feet the door pocket. These door pockets were designed too large or pertruding to far out. And sometimes interfere with the stepping off of the vehicle unless the door is open all the way outward. When I purchased my vehicle I noticed that the right rear passenger door pocket was missing. Obviously it had been snapped off as well. I contacted Hummer parts dept. in my area for a replacement pocket. And sure enough, I was told that I would have to purchase a whole door panel at the tune of $600. So I got a little creative and went to the local bargain store in my area and purchased 2 "drawer organizer" bins made by "Rubbermaid". www.rubbermaid.com One measures 9x3x2, Part #L3-2915-P2-WHT and the other measures 3x3x2, Part #L3-2919-P2-WHT. I made 6 small holes on the side of the larger bin and 4 small holes on the side of the smaller bin. I then removed the door panel being extremly careful not to break the door panel at the hold down points. I placed the bins where the pocket was sitting, one on each side of the pocket divider and slightly above the floor level of the truck, lined up the holes, marked on the panel with a marker where the holes are, I then drilled 10 small holes on the panel on my marks. After painting the bins with spray paint, I then fastened the bins to the panel with plastic tie-wraps. PERFECT! The door closes fine with no interference and I have useful pockets on this door panel again. If you would like a photo, I can send one. A picture is worth a thousand words.
Man1nboat
12-04-2012 11:03 AM
benhayes
08-24-2012 02:36 PM
aaronballard0033
07-15-2012 11:51 AM
littlehummerboy
06-13-2007 07:30 PM
