Need more heat
RE: Need more heat
For more heat... the H1 doesnt really have a good heater core... only thing you can do is make sure your coolant is topped off and when at redlights i usually idle around 1600-2000...
Next year there may be an accessory to help with the heat... I am currently working on some templates that hopefully will keep our engine temp at 200 during the colder winters and it will be a bolt on accessory no mods at all and can easily be taken off for the warmer months or "opened up" for the warmer days/high way travel in the winter months....
but sad to say it wont be out till next year
RE: Need more heat
I'm up in Alberta, Canada. And the Scotch up here is getting very expensive. The wind chill is -56. I have the motor tarped up it's running around 220 degrees, im getting decent heat in the back, but not much up front.
Koboss
Koboss
RE: Need more heat
If you are getting good heat in the rear but not in the front, I would suspect something isn't working properly; you may want to have it checked out to make sure that there isn't a gate/flap stuck partway open, a loose vacuum hose connection, or a problem with any of your duct/connections.
There are also heat shields in the area below the transmission shifter, e-brake and t-case lever -- I found that with those removed, more engine/exhaust heat comes up into the cab in that area.
You can also buy a small 12v heater/blower and aim it directly at yourself (or a passenger) -- it doesn't have much of a range, but I got one and my wife loved having another area of warm air to put her hands in front of, etc.
Kreke
10-10-2008 07:07 PM
OnAll4s
05-06-2008 09:26 AM
