Need help on ABS and TT4 lights stay on
Old 08-11-2010 | 06:35 PM
jameshd's Avatar
Default Need help on ABS and TT4 lights stay on
Hello all,
I am new on a Forum. Just bought a 2000 H1 wagon, after undercarriage with a powerwash ABS and TT4 light came on. I shorted pin# 4 to pin# 15 and I got code 2-6 on ABS light flasing.
Please anyone advice.
Thank you in advance
Jameshd
Old 08-12-2010 | 01:18 AM
Check the tone rings on your half shafts.
Old 08-12-2010 | 11:05 AM
jameshd's Avatar
Thank you 3Hummers for your advice, I had cleaned out tone rings with WD40, but lights still stay on. Would you please give me more details how and what to look for at the tone rings.
Old 08-14-2010 | 10:36 PM
jameshd's Avatar
http://www.landroverclubvi.com/abs-mod.html
Please check the above link for ABS modulator repair for ABS and TT4 problem.
Old 08-15-2010 | 02:16 AM
If you powerwashed them you could have bent them slightly. They are pretty distance sensitive.
Old 08-16-2010 | 10:15 PM
Forsche's Avatar
Default ABS and TT4 lights
I just had the same problem today. I had the H1 in the shop to repair some CV joint boots and drove it for one day and I have the same problem and they also repaired the seals were the halfshafts go into the hub. Scanned it and it came up with 4 codes two had nothing to do with it but they are looking at it.
I hope its not expensive. I just spent $5K on the girl.
Forsche
Old 08-24-2010 | 11:05 PM
Forsche's Avatar
washed my half shaft rings and after a few minutes of driving the lights when off. Cool she's good as new.
Old 08-25-2010 | 09:01 PM
Forsche's Avatar
I've read different ways to adjust the speed sensor. What is the best way. One guy says a hammer and a credit card for tolerance.
Please let me know.
Forsche
Old 09-17-2010 | 10:38 AM
jameshd's Avatar
I bought an ABS modulator of Land Rover Discovery II off ebay for $150.00 Took it apart and replace a shuttle valve on my H1. Code 2-6 and lights are off. Thank you for all of the advise
dyydjbb
09-19-2014 03:12 PM
Bryja12
08-12-2010 10:57 PM
tavion2378
03-24-2009 01:22 AM
ecpmd19
03-11-2008 09:49 AM
H14baja
05-30-2006 08:49 PM
