nav unit antenna
Anyone have a factory installed nav unit? If so, where does the antenna mount braket attach(metal braket with a couple of holes in it and abouta foot of antanna wire from the back of the unit to this mounting plate)?
ORIGINAL: CCMDoc
According the service manual it is located behind the left center a/c duct. The manual calls for the dash to come out to get to it. The next time we have a dash out to replace a heater core I need to take a look at where it is. If I get lucky it will be one with navigation. Steve
ORIGINAL: H3X442
BTW, what is the P/N for the service manual? I have them for every other car I have owned and they are invaluable as you already know.
I got a look at a factory nav unit and where the gps ant. goes. You do not need to remove the dash *(like the sevice manual states). It is located at the firewall behind the radio near the left center a/c duct. There are 2 mounting tabs/towers that you screw it to. They are a little tricky but see no problem installing it. Steve
ORIGINAL: H3X442
Do you know which amplifier goes with the oem nav unit vs what goes with the oem single CD stereo?
My On-Star and Nav volume is almost too low to hear.Nothing I do makes it loud enough.
I suspect a different amp is used witht he nav unit vs the base OnStar/XM/Single CD unit I have.
Paul
Tram
07-21-2011 12:08 PM
ssanders
12-10-2007 07:56 PM
wellperfused
11-09-2007 02:17 PM
tarheel_34
03-18-2007 03:29 PM
