My new stereo/ideas for others
This is my new sound system I have had installed this past week I am posting mainly to give people ideas if they are considering changing out or upgrading their systems. The system stats are, Hifonics 1210d 1200watt amp that is put in the left rear cargo panel, A 1000 watt pioneer premier 10" subwoofer in a custom fiberglass enclosure in the back door. Back up camera is pioneer nd-bc4 2010 model. I was very suprised with the light the camera picks up at night the image below is in almost pitch black.Just the break lights without foot on break and what ever light the light post is giving off from across the street created the light for that image. The head unit is the pioneer avh3100dvd this head unit gives a nice boost to the stock door speakers I feel. I also had the pioneer xm module put in to keep satelite radio the bluetooth was not effected and onstar works fine with the gm module you use when changing out headunits. The sound system is far superior to the monsoon system in my opinion and was cheaper by about 400 dollars my total cost with installation was just under $1500. Any questions I will do best to help thanks for checking out my post.
nice setup man, i just bought the pioneer avic-x910bt and i'll be installing it myself, hopefully it's not too hard. did you have them install it so that you could play DVDs on the road?
i'm loving that sub in the rear door, wish i had the ability to do that myself
side note, where in jersey are you from?
I just purchased a regular harness but there are 2 connectors 1 plugs into the back of the stereo but the other little one I have no idea where it goes. And that little wire has the acc wire that I need to turn on the radio any body can help me?
I had the work done at bumper to bumper in freehold nj. The actual install costs including the gm module for onstar wiring and the back up camera was around 850 dollars which isnt bad considering module and the camera were 300 right there . I have known the guy for years and really is the only one around here who has worked on a few h3's so I went with him. I bought all the components speaker headunit and amp online and saved about 150 dollars doing that.
The second wire I believe goes to the gmos 01 module you use to keep car chimes and onstar and the one wire your referring to thats acc if its blue it should be the remote wire which tells the amplifier when to turn on and off with the radio. If its a larger black wire its the wire you put an adapter on so you can connect to the cars radio antenna. I only am guessing based on what I read and when I did a aftermarket stereo in my old pathfinder.
^ I purchased the pioneer avh-p4100dvd and I bought a harness that has a larger clip that clips to the original wiring harness then it also has another clip I'm assuming that goes to the gmos module. But the harness does not come with an acc wire or engine ignite wire (whatever its called) so it can never tell the radio to turn on. Where do I run the acc wire? Can I just splice it into the yellow wire for the battery? Where do i connect the little connector I dont see where it would fit anywhere, after I connect the big connecter to the factory harness?
Tony-
You said the factory bluetooth was not affected by the radio switch? I have a 2009 H3, so it has the factory bluetooth... if I installed a DVD/NAV unit with the Onstar adaptor, I'd like to still be able to use the factory bluetooth. I'm not keen on installing a new microphone, etc.
