My 2003 won't go into 4hi lock or 4low lock
Sorry if this has been discussed a lot here, but I've been searching for a couple hours now, and still can't get a definitive answer..
My problem is that when I try to switch into 4hi lock, or 4low lock, the light just flashes several times, but does not switch out of AWD.
Anyone know whats going on here and how I can fix this?
Its been forever since I needed to use mine, but try putting it in neutral with your foot on the brake & then pressing the button.. Same to take it out.. It wont switch in park or in gear if my memory is correct.. Again it has been a while , but I think that should get you in & out... J
Yea, I've looked up the price for one, and its about $173 from my local Oreilly. I wish I had a wiring diagram of the system so I could make sure thats the case before I just buy one since you cant return electrical parts if they have been installed.. Anyone have a schematic of the 4wd wiring? I looked for a fuse in the fusebox under the hood by the battery but didnt see a fuse that I thought would pertain to this problem.
On a side note (maybe related?) my TCS and ABS lights are on. I am pretty sure thats due to a faulty wheel speed sensor since that same exact thing happened to my buddy with an avalanche. Would that perhaps prohibit it from going into 4WD lock?
Yea, I found that out as well actually.. I replaced my d/s wheel hub a couple weeks ago and that cured the issue. But then led to another problem unfortunately. Now after driving a little bit, the traction control kicks in for no apparent reason, then shortly after that the ABS, TC, and parking brake light come on and display reads "Service Brake System"
I tried the fix listed in the bulletin, and it still does the same thing
this is the link to the problem.. forgot to add it in my post. I cant figure out how to edit my last post either..
https://www.hummerforums.com/forum/s...ad.php?t=16305
Can't shift out of high lock.
Could you please tell me your trouble shooting procedures and how you came to the conclusion of that exact hub please?
Thank you,
Jay
Cell. 206.226.8496. Text message also.
Thank you,
Jay
WR3NCHE4D
10-13-2018 03:05 PM
vinny1957
05-04-2014 11:47 PM
kwmamc
04-19-2012 03:57 PM
