mpg on h3
RE: mpg on h3
Not enough information to go on..you'll have to explain your driving habits, type of fuel (winter blended, etc) Air pressure in tires..Motor oil used (break in period usually takes 2000 to 5000 miles)..Weather conditions as a constant ( cold weather will eat fuel...)..
So no, there seems to be no problem from what you've told us..
RE: mpg on h3
I have averaged around 14 mpg in the past with the 2006 H3.
Check this out also:
http://www.fueleconomy.gov/feg/calcu...1&id=23410
RE: mpg on h3
ORIGINAL: RutDogg
You may want to try one of those pcmforless deals. They are supposed to boost fuel economy a little bit.
John, Have you noticed a difference in fuel economy since you purchased yours?
I'll see how the mpg is after a few hundred miles, but I personally believe without the PCM for Less tune that I would have been gettingmuch lower in the mpg with the 315's.
