Mounting a 315 spare - a little help
Old 04-09-2007, 05:38 PM
07HummerH3's Avatar
Default Mounting a 315 spare - a little help
Now that I've got my (4) 35" MTZ's, I want to get a fifth and mount the spare but it looks like there is no way it will fit without crushing the rear wiper. What have you guys (gals) don't to fit the larger tires on the spare? Thanks.
Old 04-09-2007, 05:51 PM
Default RE: Mounting a 315 spare - a little help
I think if you do go that route..you will have to put a couple of spacer/washers on the mount where the studs come through..
Old 04-09-2007, 05:58 PM
07HummerH3's Avatar
sounds simple enough, thanks.
(after I posted, I thought that I was going to be told todo a "search"- sorry if it was a stupid question)
Old 04-09-2007, 06:08 PM
Not at all bro...Don't mind me, I have a search fetish..
Old 04-09-2007, 06:44 PM
I'm using the 35" MT Toyo's and it's very close but doesn't touch the wiper at all. You might just want to put it up there and check the spacing.
Old 04-09-2007, 08:34 PM
YES THE 35 WILL FIT. I HAVE THE 35 TOYOS AND NO PROBLEMS WITH IT HITTING WIPER.
Old 04-09-2007, 08:48 PM
07HummerH3's Avatar
ORIGINAL: nascar 17
Thanks for the guidance. I think that with the tread the MTZ's are a little wider, but I'll give it the 'ole college try.
Old 04-09-2007, 10:34 PM
Ghostrider's Avatar
Im fixin to step up to a 315 soon here but the clearance I'm worried about is the ladder from my gobi rack. Its looking like its not gonna fit......anybody have big tires and a gobi ladder?
Old 04-10-2007, 05:58 AM
skeeet's Avatar
My 351-75-16 BFG MT fit fine.Sounds like the MTZ's are a little bigger given the same size because some have said they rub the stablizer bars.
Old 04-11-2007, 03:23 PM
WOLFGANGSTA's Avatar
I've got 325's on mine and I simply used about 5 standard thickness washers on the 3 studs and got the clearance I needed. Your tires will probably need less than 5 like mine did.
Quick Reply: Mounting a 315 spare - a little help
