MOD CHIP - Legit?
Old 08-21-2006 | 09:17 PM
ChevyHighPerformance's Avatar
Default RE: MOD CHIP - Legit?
ORIGINAL: CerberusSVT
our trucks run a 14.7:1 air/fuel?? thats "I hate my engine" lean in the sports car world!
Yep. When you go to WOT (wide open throttle - about 80% open) the engine goes into power enrichment and the commanded A/F goes to about 11.7-11.9 which is richer than for optimum power but conservative for GM warranties.
Old 08-21-2006 | 09:31 PM
ORIGINAL: Dennis
Yes..After that last info post I feel like a need another degree in auto emission control jargon.
My fault:
A/F - air fuel ratio - 14.7:1 for best fuel economy and lowest emissions (stoich ratio) - about 12.5 - 13:1 for best power
MAF - mass air flow meter
g/s - grams per second
MAP - manifold absolute pressure - air pressure/vacuum in the intake manifold
VE table - volumetric efficiency table - give base air mass per cylinder values in a table of RPM versus MAP - used to determine air flow if MAF dies
Strim - short term fuel trim - moves quickly in response to precat O2 values to make part throttle A/F 14.7:1
Ltrim - long term fuel trim - moves slowly to bring the Strim to zero - the total fuel added or subtracted is the sum of the Strim and Ltrim (i.e., 5% + 6% = 11% fuel added - 11% longer injector pulse width)
WOT - wide open throttle - usually throttle >80% open - no A/F learning - Strim forced to zero
IAT - Inlet air temperature sensor - located inside MAF - electrically independent of MAF
ECT - engine coolant temperature sensor
Open loop - PCM adjusts A/f based on predetermiend values - usually when cold
Closed loop - PCM adjsuts A/F based on precat O2 to make A/F = 14.7:1
cprusik
07-29-2011 06:18 PM
touchdown227
03-25-2011 08:16 AM
empoer sztoid
10-28-2007 03:00 PM
GorillaH2
10-24-2007 08:35 PM
rynpamn21
03-23-2006 08:08 PM
