mild front torsion bar lift w/bilstein hd's
Hello and Welcome from MI!
Please, use the SEARCH function at the top of this page and enter "torsion bar bilstein". There are about 50 Threads on this exact subject. Read through them and see if they answer any of your questions and concerns.
I haven't seen a listing for a Bilstein HD for the H3 (Stock or "t-bar cranked") so I assumed you ment the 5100s. The only options as of right now are the :
Part Number: 25-176407
Setting: 5160 Series
Position: Front
Descriptor: Front Lifted Height: 0-2.5"; Torsion Key Lift
*Collapsed Length (IN): 12.83
*Extended Length (IN): 16.3
*Collapsed Length (MM): 326
*Extended Length (MM): 414
Old Part Number: F4-BR5-H640-H0
Part Number: 24-186643
Setting: 5100 Series
Position: Front
*Collapsed Length (IN): 12.54
*Collapsed Length (MM): 318.5
Old Part Number: F4-BE5-C153-H0
Part Number: 24-187091
Setting: 4600 Series
Position: Front
Descriptor: Standard Suspension
Old Part Number: F4-BE5-E672-H0
Part Number: 24-185615
Position: Rear
Descriptor: Rear Lifted Height: 0-1"
*Collapsed Length (IN): 16.18
*Extended Length (IN): 26.2
*Collapsed Length (MM): 411
*Extended Length (MM): 665.5
Old Part Number: F4-BE5-6254-H6
The list above is directly from Bilstein/Cognito. I would ask a lot of questions or get the model # and look them up on the Bilstein/Cognito site and see if they match the length, and the mounts (upper and lower) of the above mentioned shocks.
We did the T-bar lift and have it at 23-1/2". Installed the 5100's with 1/2" extended bump stops. Also installed Bilsteins on the rear. Rides great and I would recommend this to anyone wanting to level their rig.
Panzerh2
65
11-04-2016 12:15 PM
sinful7
08-10-2015 07:05 AM
Todd Edge
06-06-2013 05:09 PM
