Max Tire Size without Torsion Bar Adjustment or Extended Bump Stops
What is the maximum tire size I can run without having to crank the torsion bars or add extended bump stops...
I know some H3's come with 295/75R16's... but what is the max you can go?
Can you do 305/70/r16's or any other size larger then the 295's?
315/75/16 w/o anything
https://www.hummerforums.com/forum/s...081#post219081
but.... i just purchased the trail duty kit because i want the extra lift.
if you're going to spend over $1K, $209 for the kit is not expensive
I had a problem running Java on my computer so I tried this link:
http://www.discounttire.com/dtcs/infoTireMath.dos
pretty good too
pretty good too
Will there be power issues with the I5?
Will I have issues with the dealer if I have mechanical problems... say with the tranny?
Will there be shifting issues with the automatic?
etc...
That's a good question...
If a dealer wants to be nasty they can deny any drivetrain warranty work based on the tire size being larger than what comes from the factory (285/75R16 max on the Adventure Package).
