Lookin 4 a H2 alarm paging add on
I would like to add a pager to myfactory H2 alarm.
does anyone know what brand of car alarm paging system that will hook up for an "ez install" to the factory H2 alarm?
some systems are plug and play, i just dont know the correct one to buy.
it will be a self install, so it has to be EZ stuff for me to knock out myself.
RE: Lookin 4 a H2 alarm paging add on
imho, i would go with an entirely different setup as far as alarms, less hassle.... the "stock" alarm that comes on most gm cars don't have shock sensors, so as long as they don't open the door they can bash ur window & you won't hear your alarm..
Yeah....DITCH the WHOLE OEM one!!!!
This is the one I have!!!! BAD ***!!!!!
Up to 3000* feet of Range
This new CompuStar Pro 2W9000FMR remote has a built in clock, in-vehicle temperature readout, and battery voltage sensing. This system operates at a higher frequency to allow for greater range and battery life. Firstech engineers were the first to perfect 900MHz FM for vehicle security applications and we've taken this technology to the next level with the 2W9000FMR Pro.
*Range is quoted for U.S. models only. International models will differ in range.
Includes 1 x Two-Way and 1 x One-Way remote
View the manual for the P2W9000FMR
View the manual for the P1W900FMR
Pro Remote Features
- Two-way paging remote
- New multi-color LCD (liquid crystal display)
- CompuGlow backlight
- Vibration and audible notification
- Clock display with alarm
- Internal vehicle temperature display
- Parking Meter timer
- Button lock
- Timer Start Mode
- Cold and hot starting with temperature
- Run-time indicator (extendable with remote)
- Turbo Timer (extendable with remote)
- Secure Auxiliary Mode
- Shock sensor on/off through remote
- Passive mode on/off through remote
- Valet mode on/off through remote
- Uses standard AAA 1.5 volt battery
Pro Alarm Features Pro Starter Features Pro Alarm/Start Features
- Includes starter-kill relay
- Battery backup capable
- External Siren (six-tone)
- Optional super bright blue LED
- Driver's priority unlock
- Ignition controlled door locks
- Includes dual stage shock sensor
- Secure valet switch
- Anti-Jacking mode
- Remote Paging System (can unlock vehicle via pin code)
- 2-auxillary outputs, expandable to 7 with Channel Expander
- 2-programmable inputs
- Selectable trunk release output
- Horn trigger output - Includes anti-grind and starter-kill relay
- Factory Style Alarm, monitors doors and trunk
- Time start set on remote by user
- Optional external Siren (six-tone)
- Diesel timer built-in
- Manual transmission compatible - Includes anti-grind and starter-kill relay
- Anti-Jacking mode
Pro Remote Features
- Button lock
- Timer Start Mode
- Anti-Jacking mode
- Anti-Jacking mode
[sm=interesting.gif] looks like anice setup... wouldi have to order online or is it available thru retail stores?? i have the viper pager alarm that thing sucks def. not recommended... so i'm looking for an alternative...
ORIGINAL: CRXMA22
Just click on LOCATE a DEALER:
http://www.compustar.com/main.htm
I paid $700 CDN installed, taxes included!!!
justin67
12-18-2010 01:12 PM
TShepp
32
03-19-2010 11:24 AM
