Leveling kit VS. Torsion bar adjustment
RE: Leveling kit VS. Torsion bar adjustment
there is no negative. If you go nuts on the amount of turns then you may have a harsher ride, other than that nothing else negative. You can even get your local dealer to do it so obviously GM meant them to be turned I have had other trucks with them cranked for many many years and never had anything fail prematurely. Do a search under my name and tortion bar as the subject, I posted an article from a t-bar manufacturer that covered the entire thing in depth, good read if you can find it.
I have a question on turning the torsion bars? Why don't they come from the factory turned up?
I know that a torsion bar adjustment is meant to be adjusted when the front end starts to sag after a few years of use and that is why there is adjustment. To adjust more than normal Factory specs to me is asking for problems later. Just my .02.
ORIGINAL: H3_Hummer
I'm in your camp regarding this. There is too much "torsion" that is being applied to the bars when they are all cranked up. For me, the Truxxx (or similar) was the only option. Ride, handling, etc all remain exactly like factory set up....but now I'm level.
ORIGINAL: H3_Hummer
ORIGINAL: importkiller
There are alot of options as to why you would normally need to adj the tortion, which is why gm sets them low to allow for room as individual situations dictate. For one, if you have a push bar and a big azz winch up front, more than likely your front end is going to dip lower than a stock base model with no hardware hanging off the front end, so you will have to adj. up in order to compansate. Actually the re-adjusted keys change the stock geometry by lowering the position of the bar, wher as cranking them retain the stock location. Basically turning the t-bar is like putting a bigger rubber spacer in a solid axle spring to achieve lift. Remember guys, the t-bar is nothing more than a spring tube (lack of a better term) if you stay under 6 cranks or so you will not make the ride any harsher at all and if you go 6 cranks plus then you'll need to replace the bumpstops with a ultra thin model to allow more flex. You could also change the stock t-bars for ones that are stiffer and achieve lift that way as well....just cause your changing GM's stock setting means nothing in regards to running into trouble later...if adjusting them was a bad thing dealerships wouldn't do it and GM would of designed it with no adj in them.
