LED turn signals flashing fast
I just added LED lighting to the rear tail lights and front turn signals of my H2. The rear lights came with resistors so after I put them in the lights flashed at a regular rate but the front lights didn't come with resistors and now all of my turn signals flash fast. Does anyone know what size resistor will fix the problem? Also, which wire do I hook them up to?
If you have to get a cheap pot tune it to what your looking for then use an ohm meter to figure out resistance. No ohm meter and a volt meter you can use a known resistance to create a voltage divider to come up with the unknown resistance. Course it is probably the same as the rear and you could just measure it worse case.
bobh002
09-06-2007 06:59 PM
