Leaking seal? Maybe?
If you are going to do it yourself PLEASE buy the Kent Moore Axle Seal Protectors, Part# J-44394?
If not, when you put the half-shaft back in you are scaring/cutting the seal. I got a whole bag of 25 of them off ebay a while ago for under $2 each. I give'em away to other HUMMER owners when we are wheeling together.
H3 axle seals!
Hello, i have a 07 H3! Luv it! I am in the process of replacing both seals and cv axles. Where can you get the kent moore axle seals? Are they better then the skf seals? I am needing 2 seals. Thanks and any help would be greatly appreciated.
Windycitykid, as stated above, the Kent Moore seal protector is an installation tool only. As Mutaint said, it just protects the seal from getting chewed up by the half shaft splines and gets removed after the axle splines are inserted past the seal surface.
The GM OEM part # for the axle seals is 15286593. Stick with the OEMs , as others have tried other aftermarket brands and they have reported fluid leaks after installation, gone back to the OEMs and no leaks after replacing the aftermarket seals.
windycitykid and Norinco, PM me your addresses and I will send you both a couple of the Kent Moore seal protectors.
Diff seal
Are the seal part #'s in this thread for H3 or H2 or both ? thanks, Cowboy701, never mind I see now I am on a H3 thread, but I also have the diff drivers side seal leak but can't find the h2 fix
