Key to Roof Rack
Old 02-12-2008 | 08:52 PM
OFFBT's Avatar
Default Key to Roof Rack
Hey to everybody, just bought my first Hummer (07 H2) and noticed that my key does not work on the roof rack locks, I bought it used and was wondering about it.
Old 02-12-2008 | 09:14 PM
xzachx2112's Avatar
Default RE: Key to Roof Rack
id try contacting the prvious owner and ask about it
Old 02-12-2008 | 11:42 PM
Or a local dealer, or a locksmith!!
Old 02-13-2008 | 12:35 AM
bluezgo's Avatar
My rack had the same problem, I just called hummer with the serial number that is on the key lock and they sent me a new one later that day. For free even.
Old 02-13-2008 | 09:43 AM
Mine got to be pretty difficult to open and you had to really work them. Did you try using some graphite in the luck?
Old 02-13-2008 | 12:09 PM
pteam's Avatar
Isnt the key only for separating the rack from the sliding mount its on? Who does that? You can add it and remove it from the vehicle without the keys right?
Old 02-13-2008 | 12:18 PM
Trey124's Avatar
ORIGINAL: pteam
Not on the H3 you need the key in order to move the rack. You really lock down the cover that goes over the the roof rack assembly.
Old 02-13-2008 | 03:03 PM
pteam's Avatar
Well on several of my h2's I have never used the key to remove or put on the roof racks, the key only separates the actual rack from the holders, I believe.
Old 02-13-2008 | 07:32 PM
SafariHummerH2's Avatar
Hello Friends, The key in H2 racks is for removing the end cap only. Upon removing the end cap, and sliding out the vinyl cover strips you can then slide into the rack any exclusive H2 rack accessory ie: OFF ROAD LIGHTS, ROOF CARGO CAGE RACK, SKI HOLDERS, SURF BOARD HOLDERS, BICYCLE HOLDERS etc. I also did not have the key for my end caps but I was able to remove the end caps with absolute no difficulty. I pryed out the vinyl cover strip from the rack and with some manuvering with a long thin flat end screwdriver on the inside portion of the end cap, I reached in and I was able to pry the closing cam just enough to clear the small bump and slide out the end cap with absolutly no problems. And to return the end cap, I just slide the end cap back into place and gave it a good push back into its locked position...no problem and absolutly no damage was incurred.
Old 02-13-2008 | 08:38 PM
But keys would be easier. My 3 doesn't have the racks. My H2 did and the key was just to remove the end caps. I only took them off to put on my two storage pods when I went to the mountains. Safari your method might work with nothing on the roof but with the two storage bins up there you wouldn't be able to get into a position to do what you did. The dealer should be able to get you the correct keys OFFBT.
DennyOK
10-31-2012 12:01 PM
purepowerH2
08-04-2010 03:50 PM
redh3
02-24-2010 06:12 PM
madmike
02-08-2010 01:38 PM
finall
08-10-2007 01:47 AM
