its winter again. How do turn off the abs again?
The icy roads and ABS are not a good thing... almost hit a few prius's on the way home.
That feeling of helplessness skidding on ice with a truck as big as the h2 is not funn.
I remembered to hold the TC button for 5 seconds but that didnt work?
Thanks in advance!
________
PORTABLE ELECTRONIC VAPORIZER
Thanks in advance!
________
you want your abs off??? but, you just pull the fuse for it out of the fuse box. im not sure which on it is, the manual should tell you. on the 05, the fuse box is the box directly behind(towards the back of the truck) of the battery(front left corner of engine bay).
Albeit you would need to redo this process everytime the vehicle restarts but safer than a permanent solution which will most likely be forgotten about in the spring
ps... the hummer is a much better snow & ice vehicle with the TC and ABS off.
________
VAPE INFO
Hmmm....well generally I would try to be diplomatic, or sugar coat my resonse to some degree, but you're an idiot. Why would anyone in their right mind want to disable ABS? It's by FAR one of the best safety inventions since the seatbelt. Disabling it would be ridiculous and irresponsible.
I hate ABS. I learned to drive up here Canada eh, where we actually have winter. Every car I drove growing up did not have ABS. I remember the first car I drove with ABS and within a month of having it the ABS fuse came out. That **** kicks in when you don't expect it to all the time. If you understand the conditions you are driving in and you learn how to properly use your brakes/steering you do not need ABS.
ABS was invented to assist the "average joe" driver who has no idea what to do when driving calls for more than just "go and stop"
And don't even get me started about ABS and off roading.......
