iPod interface options
Old 01-26-2010 | 02:20 PM
supsam86's Avatar
the metal bezel comes off extremely easy:
1. take the caps off of the two 12v sockets
2. stick a finger in each socket
3. lift slightly up and out
4. pull gently out from bottom to top
5. pretty much pops out on its own
6. disconnect all the wiring harnesses
7. done, no tools needed.
edit* : you might want to disconnect the battery before sticking your fingers in the sockets, I didn't but I don't want to hear about it if someone manages to shock themselves... even if you do, you'll be fine.
Old 01-27-2010 | 12:52 AM
worknit's Avatar
Default iPod Touch
I have Monsoon 6 CD/ XM Radio setup. Went with USA SPEC Model PA11-VETTE, along with ProClip Center Mount , padded holder with tilt swivel and swings 360.
I can control by both by iPod or XM1 which control play, pause, fast forward, next or previous play
USA Spec control module also has additional A/V input for DVD or Satellite receiver. When I get around to mounting my DVD Headrest players, I’ll have a feed into it, so I can enjoy same movie as rear passenger
I spend most of my driving time with music videos playing over the system.
Old 01-28-2010 | 11:11 PM
hearseman's Avatar
... the iSimple had to come out. It started with a Service 4 wheel drive error, then it caused the H3 to throw all sorts of codes. The dealer took it out and reprogrammed the computer. I've not had a problem since.
Old 01-28-2010 | 11:40 PM
drtom's Avatar
Banned
Default metal plate,,ez
i used two fingers only, pull out bottom and work up SLOWLY. ITS amazingly ez but the shifter gets in the way
so dont scratch it too much!!
tom
and dont worry you cant get shocked on 12 volts!!
Jaydawgx7
03-23-2010 10:01 AM
2006hummer
12-21-2009 09:55 PM
steveng
10-21-2009 02:59 PM
SublimeHummer
19
02-03-2009 12:51 PM
studio theater
08-18-2008 02:46 AM
