Ipod Hook-up
RE: Ipod Hook-up
I have the Nav System and the XM which I had converted to SIRIUS - the installer pulled the entire silver face plate off which surrounds the radio, vents, etc and accessed the XM directly behind it (I believe it is refered to as the head unit). Mine wasn't behind the glove box. Hope that this helps.
RE: Ipod Hook-up
ragz12,
Sounds like no you should not be doing this. You have to remove the faceplate of the dash to access the head unit. The screws are right there staring at you.
Check out http://www.rausite.com/hummerh3.htmfor pictures of a stereo removal.
RE: Ipod Hook-up
Skoal,
Thanks, this is exactly what I needed. It looks like the XM unit is below the radio. If that is the case then all I need to do is remove the bezel to install the Nexus. Wish me luck.
RE: Ipod Hook-up
ORIGINAL: ragz12
Thanks for the info. Sounds like alot more than a 10 minute install. Where are the screws that hold the head unit located? Is this something I should be doing myself?
