Hummer H3 Transmission Issue Need Help
anybody know what could be wrong with my 2006 h3? the transmission will sometimes not shift into 4rth until the car is shut of and restarted. It will also get stuck in a gear while hitting bumps on the backroads for instances like 3rd gear and wont shift until restart the vehicle. Car has 151k miles and tranny fluid was changed at 120k. I have checked transmission level and looked at fluid color. No burning smells and it doesn't shift hard or slip. When it wont shift into 4rth the gears bog out and does not want to down shift until I step on the gas more. I'm hoping this is a bad ground or something simple. I also want to mentioned I had issues with the key ignition around 130k miles if that has something to do with this issue.
No need for repeated duplicate posts....
Might want to look at the other recent post on this topic also at the front of the board. https://www.hummerforums.com/forum/h...-50-mph-35666/
When they do not hold lockup, it most likely means rebuild time.
Whenever rebuild time rolls around, I usually go with heavy duty aftermarket parts in a few areas, which boosts the costs, but I think its worth it.
Hello everyone sorry for the duplicate posts new to the site. I talked with my friend who is a GM certified mechanic and he ran me through a bunch of different causes to this problem. My issue ended up being my amp and subwoofers robbing my system. I also had a cold air intake that I put on the same time I hooked up my system. I removed both and it runs perfect again. If anyone adds in a system watch for issues like this cause it may be the problem. Also read that the cold air intake is bad for dusty roads and for my engine because I have the little 3.5l and it doesn't help getting dust in the engine. Didn't really notice a difference in performance either with cold air intake just stick with an aftermarket exhaust.
There are two bolts in fuse box and I tagged my amp cord onto the hot wire. Which in return was drawing power from my electrics. I did not put the amp directly to the battery. When I unhooked my system and drove on the same routes and tried to recreate the issue it wouldn't do it anymore. I hooked up the amp and subs back up the same way again today drove the same roads and it messed up my cars shifting. Did this to make sure it was the problem and not my transmission failing
a7m1
11-06-2020 09:22 AM
linsys
07-24-2014 08:55 AM
mdromanelli
09-30-2012 08:50 AM
mdromanelli
09-22-2012 08:16 AM
only_zeek
07-19-2010 11:03 PM
