Hummer H2 Differential lubricant
Hey everyone, I'm going to be replacing the fluid in my front and rear differentials this weekend, and it says to use 75W-90 Synthetic Axle Lubricant in the manual, use either the GM stuff or a 75W-90 Synthetic Axle Lubricant that "meets GM Specification 9986115."
I was looking at the AMSOIL Severe Gear 75W-90:
http://www.amsoil.com/storefront/svg.aspx
However I'm not sure if it meets GM specs 9986115.
Has anyone else had this issue? Are there any other fluids from other brands I could use? Any input would be great, thanks!
I would think the Amsoil would meet or beat the GM oil. When I had mine changed at the dealership they did not add any modifiers to the oil for the posi limited slip. Not sure if the Amsoil is the same. On my Toyota Land cruiser has the same thing done at the dealer. When I got it back it would clunk around corners. Dealer added the modifier and the noise went away. MAy not hurt to add some while your changing the oil.
motley1987
01-28-2014 07:57 PM
danist
08-24-2007 07:18 PM
HummerGuy
20
12-22-2006 02:14 PM
03, diff, differential, fluid, fluids, front, h2, hummer, kind, lube, lubricants, mobil, oil, rear, recommended, synthetic, transmission
