hooking up brake controller
I have to pull my tandem cargo trailer out of storage this weekend and I am going to hook up my prodigy brake controller. I know where the wires are and have the adapter, what is the best method of hook up? Should I just use heat shrink tubing?
I also checked in the fuse box and the fuse are in there. Now with my previous ford truck I had to add a relay switch, which of course was wrapped up in the glove box. Will I need one for the H3?
I was surprised how nice it handled the trailer. I use to pull it with my 07 f150 which has double the towing capacity. It was very smooth and turned well. The front end did lift a bit but nothing worth worrying about. I know that I can't load the trailer with too much weight like before (7500lbs total weight) but that just means more delivery of material.
Not sure if your 07 has the same engine or a better one but I'm sure it will handle it. When I was shopping for trailers, I actually hooked them up and went for a test drive. I would test it out at the dealer, same as test driving a car. Some trailers are built better than others and you can tell the difference when towing.
good luck
good luck
H2CANEPADESIGN
10-22-2011 08:15 AM
