Help with wheels
Old 03-16-2012 | 07:02 PM
firefighter1133's Avatar
Default Help with wheels
What other trucks have the same bolt pattern as the H3? I cant find any 20s or 22s to fit mine. But a buddy has some 20s off a silverado and IDK if they will fit.
Old 03-16-2012 | 07:47 PM
Bunger's Avatar
The bolt pattern is 6X5.5"
But there is a lot more to be concerned about when deciding on which wheels will fit.
First is that H3 wheels are Hub Centric, meaning that the center bore MUST be 101mm to align the wheel to hub. A lot of wheels are Lug (or Stud) Centric meaning the wheel lugs do the aligning. Most Lug Centric wheels will have a much smaller center bore that won't work on a H3.
You also must have the correct Backspacing, meaning the distance from the Hub to the wheel mounting surface.
And you need to know what Offset you need, to prevent rubbing on the sway bars or fenders. That changes based on the wheel width.
So lots to think about and 20's to 22's ? Rethink that too. 18's or smaller look best on H3s. More rubber, less wheel.
Old 03-17-2012 | 02:58 AM
X2 on EVERYTHING BUNGER said esp. the "20's to 22's" comment!
BMoney5327
05-07-2012 08:36 AM
importkiller
29
01-15-2008 03:51 AM
hilljob26
09-26-2007 06:00 PM
diamondh2
01-12-2007 12:10 AM
thaidoggs
12-28-2006 07:26 AM
