Help with radio
Old 01-10-2010 | 10:01 PM
Hummer05's Avatar
Default Help with radio
I have a 05 h3 hummer and when you take the key out and get out of the car the radio does not go off. You have to open and close an other door to get the radio to go off. Does anyone know what my problem is and how I can fix it?
Old 01-10-2010 | 11:00 PM
drtom's Avatar
Banned
Default right
thats so u can listen till you go
thats how it works according to the book
so just get out!!!
tom
Old 01-10-2010 | 11:12 PM
Hummer05's Avatar
After you get out and close the door it keeps playing it will play all night long.
Old 01-11-2010 | 02:17 AM
TShepp's Avatar
Sounds like the driver door pinswitch/sensor might be bad. Does it tell you the door is ajar if you turn the key on and just open the driver door? Also, the radio only plays for about 15-20mins it will not play all night long when left on Retained Accessory Mode.
Old 01-11-2010 | 08:51 AM
HumbleAg's Avatar
That's a special with the 05 model. When they actually went into production with the 06 model they fixed that problem.
Old 01-11-2010 | 10:08 AM
drtom's Avatar
Banned
Default Oops
man i thought i read that right, im wrong, pretend i wasnt here!! gbye
tom
Old 01-11-2010 | 08:14 PM
Hummer05's Avatar
It never tells you about the door being a jar or open.
Old 01-11-2010 | 11:54 PM
TShepp's Avatar
You have a bad door latch sensor for the drivers door then.
Old 01-12-2010 | 12:15 AM
Hummer05's Avatar
Where is this part located on the door and how hard is it to change?
Old 01-12-2010 | 02:34 AM
Tonyg41's Avatar
I just turn my radio off whenever im getting out , as a habit but you should have that checked out since it could lead to a dead battery one day if it turns on when not suppose to.
