Help with poping ,rattle noise behind dash
Old 07-24-2014 | 05:53 PM
bosch's Avatar
Default Help with poping ,rattle noise behind dash
This just started ,getting poping rattling noise from the dash
Sounds like it's behind the radio.
It's worst when cold but happens when warm also.
With key on but no engine run it won't happen.
With engine running and radio off climate control off .
And in park it happens , I did have the cluster gauges
Changed out last year but it dosent sound like it's coming from there.
Can't pin it down , any help please and thanks . Mike
Old 08-02-2014 | 12:19 PM
bosch's Avatar
Default Update on problem
I removed the cluster and still have the noise, so I pulled the top
Dash pad off, I hate those screws should have used clips the screws
Pulled threw one plastic part and were hard coming out, not a good
Design .but anyway the noise is not coming from the climate control
Eather it sounds like it's coming from the heater box at the top.
Like when the water is getting hot it's making noise. Not sure of the
Problem or fix. I wonder how hard would it be to replace the heat exchange
On an h2.? Any input would be helpfull, thanks Mike .
Old 08-02-2014 | 05:00 PM
bosch's Avatar
Default Still more info
I found some info off another web sight, I guess this is a known problem
With Gm 6.0 engines, the heater core is the highest point in the cooling system
And if air gets in the system it will end up at the heater core causing all kinds of noise . Some say to back flush the core and then refill and purge the air out,
Some just burp the upper radiator hose and they also recommend changing the
Surge tank cap. So I will give it a try. Mike
Old 08-07-2014 | 05:15 PM
bosch's Avatar
Default Not the heater core
I bypassed the heater core and I still have that noise,
It's a pain in the rear, bugs the hell out of me ,can't figure it out,
Maybe something in the duct work, go figure, will let you guys know if I figure it out, if anybody has any ideas please chim in. Mike
Old 08-24-2014 | 12:40 PM
bosch's Avatar
I think I found the problem, behind the engine net to the firewall gm runs the 2
Fuel lines , one was moving around so I used a zip tie and tied them together ,
So far no noise . Mike
Old 08-24-2014 | 10:07 PM
LoJac963's Avatar
good job tracking the noise down. These 2's are filled with pops, cracks, creaks, squeals, and any other noise you can think of.
My wife says my 06 sounds like a commercial plane taking off with all the plastic noise when I hit bumps in the road lol. Annoys the **** out of me, I've tried putting felt pads everywhere I can but the noises just keep coming....
Tbone36
08-21-2013 12:17 PM
Johnny B. Epic
02-09-2012 10:35 AM
White Wolf
06-02-2009 07:26 AM
peliti27
08-02-2007 04:14 PM
carissa
04-18-2006 01:48 AM
