HELP! my dash display says"replace lift gate fuse"
my dash display says"replace lift gate fuse" in the message center on start upeven thought the lift gate lock works fine?iv checked all the fuses next to the drivers side dash and all the ones under the hood next to the battary. i called the dealer, the fuse they told me to check is fine they told me it could be the switch to lock and unlock the rear gate but that works fine too. every thing works fine put this display wont go away and im sellling my 2004 h2 to buy an 07 and this display is scaring away buyers anyone had trouble with this before or know somthing else i could try to fix it?
RE: HELP! my dash display says"replace lift gate fuse"
It's on page 3-50 of the owners manual. It says to replace the fuse... if it returns after replacing the fuse then see the Dealer.
It refrences 5-103 and 5-107 for fuse locations.
You can get online access here.... you might need the pictures to be 100% sure...
https://www.mygmlink.com/main/US/en/gmc/home
Does it clear and then come back?? or does it not clear at all??
Disconnecting your battery for a few minutes might help if it's not clearing at all...
Hummerrican
06-24-2015 07:47 PM
Jogi
12-24-2012 08:10 AM
peliti27
08-02-2007 03:14 PM
