HELP, H3 missfiring on all cylinders
Hi all, my H3 with 55000 miles is running rough all of a sudden.
I had a tech hook up a computer scanner and this is what it found.
P0017 CKP to Exhaust CMP correlation B1
P0300 Random Cylinder Missfire
It also showed all cylinders missfiring.
Does this problem have a recall, they think it could be the Cam sensors.
Any help would be greatly apreciated. Thanks
RE: HELP, H3 missfiring on all cylinders
What year and date of Mfg. (from the door jam sticker)? More info is better.
The VVT system is remarkably reliable, but anything is possible, sensors of any/all types can and do go bad??
Also, I just bought this in Sept with 51,000 miles. It had a 60 day or 2500 warranty, I am at 5,000 but before the 60 days (Do I have any rights against this?). I guess I'm screwed, I just started reading about this head issue!!!!
GM should honor the head issue even for a used vehicle purchase, as long as your vin falls in line with the effected h3's then they know of the problem as will replace the head assy.for you....at least that's what I was told by a few dealerships.
I bought it at a Hummer dealership in MA and I live in CT (2 hours away). I'm going to take it to my local dealership and see what happens. I didn't check my VIN but is says 09/05 so I'm sure it will fall under that number. If I have to pay for this myself, is there a way to put the Alpha motor in? I wonder if anyone else is thinking about this, I think there is a problem with the frame being redesigned to fit the V8.
ORIGINAL: hummer3
Getting the head fixed under warranty, if that's really your problem,for free is the best bet.
There was never a recall on the head problem mostly because recalls are more for safety related issues and GM didnt consider this a safety issue...but there were a few gm bulletins released to dealerships about the problem and how to fix, then they sent out tsb's about what part number to use for the new heads because they had to use a new recast head that was free from problems....I'm sure you can call GM's main HQ and get something resolved if your dealer says no.
