Halo Light Rings
Halo Light Rings
Has anyone installed Halo light rings in their H3 Headlights & /or fog lamps? If so, what brand, degree of dificulty and overall satisfaction? I didn't find any info on the subject using the forum search.
Thanks,
Boomer
Thanks,
Boomer
The Halo rings on any car or truck light is cool, example to new camaro, when you can do it.I think the headlight on the h3 would need to be modded kinda heavily for the wiring and to fit the rings inside the housing. If im correct the circle in the h3 is 8" so if you can find a 8" halo ring and right wiring you could do it.
Halos Installed
I have set now in my fog lights as well.
Boominator: looks like worknit has it figured out. His install looks factory!
Boominator: looks like worknit has it figured out. His install looks factory![/quote]
It looks great! I'm looking at using blue rings for both headlights & foglamps. I found an on-line source for the H3 kit but it looks pretty involved - the light assemblies have to be cut open with a dremel tool and then reglued/ resealed after the halo rings are installed.
Well worth it in MHO.
It looks like halo ring headlights now come standard on the new Range Rovers. It sure would be nice if someone marketed drop-in H3 halo assemblies
*takes a chew* It's a bit rubbery! But thats the first H3 I've seen with halo's, and it looks amazing.
