Half Shaft HELP
Old 05-15-2010 | 01:13 AM
trich24's Avatar
Exclamation Half Shaft HELP
Hey guys it looks like my half shaft seal on the diff of my H2 is leaking quite a bit on the front driver side the half shaft itself is fine none of the boots are cracked. I've never takin the front axle etc.. apart or replaced anything. Does anyone have a write up on how to replace or issues I will run into such as such as new ball joints if they are easily broken on disassemble? I just need ANY help I want to do it quick before the gears burn up or cost me more $. Any one have that part number or where to get the seal itself if that's all I need? and additional parts you have used? Side note what is the best oil to run in the differential or what does oem call for? Not sure if it's ATF or not. Lastly do you run the same oil in the front and rear or anything special for having the locker?? THANK you so much for any and all help
trich24
05-16-2010 12:11 AM
006h3
04-30-2010 12:27 PM
theBroken
11-07-2009 03:40 PM
Todd
09-18-2008 04:54 PM
Linus Gump
03-06-2007 04:13 PM
