H3 Transfer case rattling
Old 12-12-2011 | 06:19 PM
Biglick1's Avatar
Default H3 Transfer case rattling
I have an 06 H3. It recently started making a metal to metal rattling noise from undernerath. It only makes the noise while driving and barely giving the vehicle gas. Its almost a rythmn sound, meaning it is continuous and sounds as if it is definitely something that is in rotation. I replaced the front drive shaft because it had a little play in it but the noise is still there? Any suggestions would be greatly appreciated.
Old 01-02-2012 | 12:54 AM
sandkiwi's Avatar
Check the tie rods, maybe some play at the inner end ...is similiar sound to when the propellor shaft is stuffed.....good luck...
Old 01-02-2012 | 01:06 AM
drtom's Avatar
Banned
Default tr case?
im not getting the tie rod connection
you mention tr case but it doesnt sound for sure.
did u try 4hi,4hi lock,4 lo? any difference might help.
theres a lot of stuff rotating when you move!!
you should have checked with the driveshaft out,learn something.
lube ok?
in reverse?
turning?
were you driving in a lock mode and didnt notice? that stresses everything,tr case chain.
im out
Old 01-17-2012 | 02:47 PM
potroast's Avatar
Default Are you having 4 wheel drive issues
I had an issue with my 4 wheel drive fork in the transfer case which made my H3 not come out of 4 wheel drive. It is an 06. The fork actually breaks, which could make a noise as things turn. It may not be super easy to tell if your stuck in four wheel hi. The lights on the dash will not indicate the proper 4 wheel drive condition if this fork breaks. This is a known problem in 06 H3s. If you feel this is your issue, I have the fix. It's about $500, but better than a new transfer case.
Old 01-17-2012 | 04:37 PM
Looks like Biglick was a 1 hit wonder. Posted and never came back:
Last Activity: 12-12-2011 06:23 PM
Old 09-01-2012 | 06:11 PM
Amanda Standridge's Avatar
I recently was told by a mechanic that my transfer case needs replaced... Which is over $1200. If this could have been i am open to suggestions. Thanks.
Old 09-12-2012 | 03:24 PM
Matt427's Avatar
That's possible Amanda, but I believe it's unlikely. Many mechanics would rather replace the whole unit than to open it up and fix only what is broken. I just joined this forum to get as much info on the plastic mode shift fork as I could find so that I would be better prepared to work on my sister in law's 2007 H3. Turns out her fork was indeed bad, and I am also going to replace the front output shaft drive sprocket bushing as it was pretty worn. Not counting the oil to service it when I'm done, I'll have about $35 in parts. I am a mechanic (airplanes), but I honestly don't think this fork replacement is all that difficult for an average shade tree mechanic. It's finding one who is willing to give it a go that's the hard part.
Good luck with your transfer case.
ride450
06-26-2021 03:00 PM
hudson4269
03-07-2017 10:12 AM
Lewis N
02-03-2008 09:22 AM
mh307
10-16-2007 06:24 PM
07-19-2006 04:05 PM
