H3 REAR Sunroof Drain Tubes!!
#21
"previous owner obviously didn't mess with it...
Thanks GM engineers... thanks a lot."
previous owner let it open too much!
all brands of sunroof work pretty much alike. the variable is the user. letting them open while sitting still may be cool but it lets dust/debris in. mine, 4yrs old, no trouble,zero.
#22
I mean wouldn't it be simpler just to have it completely sealed off... like why was it designed to allow water to be inside the roof? Like once you close the sunroof... no water should be able to get in.. just kinda makes sense to me.
Does this mean my weather stripping by the sunroof is bad?
why design something that closes shut.. but lets water come in and then you have to build this elaborate drain tube system, when you could have just not let any water in at all? Or is it eniviatable with any sunroof??
#23
I guess there is a reason but.. I don't understand.
its impossible to be 100 % tight.(shuttle)
i open only when flying down the road and NOT in dust/sand!
#24
GM engineers certainly shouldn't have designed the grommets the way they did. That much was pure idiocy; I don't see a single benefit from having such a small opening when a larger one was not only possible, but also logical. Further, even if there is a benefit (some people have postulated it's to keep bugs out), it sure doesn't outweigh water damage.
#27
Having this problem sucks... I kinda think my car has mold under the rear carpet... not sure but it kinda smells like it...
![Mad](https://www.hummerforums.com/forum/images/smilies/mad.gif)
Thanks GM
#29
all night, it was nicer in jan, well almost. i looked out at the puddles on the roof rear of window against the rubber. up front the glass corners were puddled and trickling over the rubber onto the roof and toward the windshield.
good time to test my "grease job". i rolled up two paper towels and tucked them into the front corners. i left them as i went to do some stuff in the garage, not long, its so cold,abt 10 min.
i pulled them and rubbed them on my cheek to test for moisture,,NONE!!
I PUSHED THSM IN AGAIN TO DOUBLE CHECK, NOTHING. ONCE MORE AND THIS TIME I "CRACKED THE WINDOW SLIGHTLy TO BE SURE THEY WERE IN ALL THE WAY, OOPS . this let in water. finally they got a trace and felt damp.
you "leakers" need to get a good look at the rubber condition,AND fit. it should be almost flush with the metal,down.020 in up front, up .020 in rear.
dont ask me about those figures, its just in the book!
mine looks like a tight fit all around and remember the silicon i use keeps the rubber soft,and clean.
#30
