H3 Performance Ignition coil
Old 10-19-2012 | 09:46 AM
Hummer_SG's Avatar
Default H3 Performance Ignition coil
Hi all.
Does the V8 ignition coil same as the 3.7 h3 ?
Other than accel ignition, is there any other plug n play ignition coil?
Thank you.
Mike
Old 10-19-2012 | 11:01 AM
I deleted your duplicate post.
The I5s use coil on plug packs, the LH8 uses two banks of coil packs, 4 on top of each valve cover, with short straight wires including heat shielded boots to each plug. No distributor.
There are aftermarket coils. What are you trying to accomplish?
You can get a bunch of ponies out of the LH8 and the stock coils are no limitation. Building performance with these motors is different than back in the day, so unless you just want some pretty red ones, if it ain't broke don't fix it. You can also get replacement wires as well.
Old 10-20-2012 | 12:09 AM
Great picture Doc, I'm going to "borrow" that one.
sagev
01-17-2013 12:41 PM
Caraddict
12-12-2011 07:55 AM
Hummer_SG
05-25-2011 01:40 PM
h2_32137
01-29-2010 01:07 AM
Mikeoj338
08-19-2008 11:43 AM
