H3 OEM Nav to CD Changer Swap
I've got an '08 Alpha with Monsoon factory navigation. I don't use the nav and would rather have the 6 disc OEM changer. The harness pins look the same on a 6 disc and the nav, should be a straight swap right? I don't see anything that would make me believe there is a "Monsoon 6 disc" headunit and a "regular 6 disc" headunit. Not like there is a sub out level control. Correct on both accounts?
Nav came with monsoon also. I had 6 cd then changed to nav. If you stay OEM the only thing you must do is install unit and then go to dealer to have vin programmed in. If you chose to swap back no issues as the original unit already has your vin programmed. When I had it done dealer charged $40
id like to have a working backup.
love my monsoon!
i have a friend working at gm dealer. ill see if he can get me fixed!
SundownAudioNY
09-06-2011 03:02 PM
Size-Matters
01-01-2011 11:30 PM
Mobiledave
07-24-2009 04:38 PM
