H3 Navigation Face Plate removal..help pls!!!
Old 01-16-2012, 08:43 AM
H3Alpha21's Avatar
Default H3 Navigation Face Plate removal..help pls!!!
Hey guys,
I just ordered a new face plate for the navigation since the buttons are all worn out..problem is that the new face plate doesnt come with install instructions..anyone know how to do this or can direct me somewhere with instructions..cant imagine it would be that hard. I tried searching but I could nt find anything...any help would be greatly appreciated, thanks!!
Old 01-18-2012, 10:17 AM
H3Alpha21's Avatar
not alot of traffic here i guess
Old 01-18-2012, 02:00 PM
Jman1928's Avatar
I havent worked with the Face plate on my H3 yet, but I have on many before this. Look towards the outer edges of the dash. Check inside the center console for screws. Once you find the outboard screws and remove them it should reveal more screws to the next piece. Hope it works out for you and let me know how it goes!
Old 01-29-2012, 01:09 PM
jvorpahl's Avatar
Just stick two fingers in the cigarette lighter holes and pull. There are no screws or anything like that.
Old 02-08-2012, 09:14 PM
Hummphrey's Avatar
Are you trying to remove just the face of the radio? or remove the dash around the radio in order to remove the entire radio from the dash?
I read it like you are trying to remove just the face. If this is the case, I know that you need to press and hold the CD eject button for like 15 ~20 seconds and it will pop out to give you access to the Navi Disc. Maybe once you have it popped out you can see if there is an easy way to remove it.
good luck!
Old 02-10-2012, 09:05 PM
kjax2010's Avatar
Where did you get this new faceplate because all of my buttons are wore out
Old 02-11-2012, 07:20 AM
H3Alpha21's Avatar
I ordered from ebay...it was the face plate for the radio with all the ***** and buttons..if u hold the eject button it will pop out and that will give you access to it...i just took it to my local audio shop and they installed it in about 30 minutes...
Old 02-12-2012, 01:35 PM
kjax2010's Avatar
Can you post the link where you got it cause I can't seem to find it n eBay
Old 02-13-2012, 07:21 AM
H3Alpha21's Avatar
Old 02-15-2012, 01:45 PM
Songman's Avatar
Interesting... But I think I'll just hang on to that $150 and put it towards my upgraded head unit someday.
Quick Reply: H3 Navigation Face Plate removal..help pls!!!
