h3 leveling shock extensions
alright,i didnt want to spend 300 bucks on a leveling kit,when just raising the torsion bars would work,the only problem is is that the shocks werent long enough,so instead of buying longer shocks for 180 bucks,i figured id make some extensions,and low and behold,works great,it retains the factort ride and lets the shocks do what they are supposed to,so i figured id pass them on to you guys.there is another guy that sells almost the same thing for 130 bucks,but you get the 2bolts to mount them with.well,i am not giving you the bolts so i figured 50 bucks shipped would be a great deal.these should work on the newer ones as well,they were made to fit my 06.i have 4 sets right now and can make more,but i wanted to test the waters.these are made out of 3/16 steel.they might be a little snug fit,but they will work,i dont like loose tolences.i have been fabbing stuff up for years,so my work is good
please ask all questions.pm me if you would like a set
RE: h3 leveling shock extensions
i was going to do that today,but it was raining here,and my garage is barely big enough for me to work in,so im hoping to get one this weekend,i have to work from 4am to 8pm the rest of the week,so i will be very tired when i get home,but i will be checkin in here off and on(at work.... hehe)
no,i have been busy building my grill guard, https://www.hummerforums.com/m_86843/tm.htm
what info would you like,theres not much to it,just unbolt your lower shock bolt.push up the shock,put these in and bolt em back up
Hey Mike.....
You set those extensions up to accommodate a front end measurement of 24.25 inches, correct?
(measured from the center of the front hub to the bottom lip of the front fender)
On my '06 that was withing .5 inches of dead level and is the measurement that Truxx and Ready Lift use.
that is about right,they are made to accomodate 2 1/2 inches of leveling,you can go that much if you crank the tbars all the way,but it is also about the closest you can go,,they measure the same as the other ones do,i asked,
