H3 leveling kit
H3 leveling kit
I have made up a few quality H3 front end leveling kits. The leveling kit is a shock extender that re-uses the stock factory shock. All you need to do is install the extenders and crank up the torsion bars till the front end is level with the rear. A front alignment is recomended, and your ready for the trails! I am selling them for $129.95 + shipping. If you would like pictures please email me. I was not able to size the picture for the forum, sorry.
If it were that easy!!! well it is kinda
u got it right it is easy to do but u are leaving some important things out aint ya? well let me explain u just cant level it up with the back, well u can but u are gonna run in to problems later like pre-mature cv joint, tie rod and ball joint wear. the correct ride height is measured from center of the wheel to the fender, and should be no more than 24.25" and u cant just align it to stock specs. eather the correct specs. are Left Caster 1.5 degrees Right 2
left Camber 0 right -.250 Toe .0312 or 1/32 toe in. But im sure u knew all this info and were planning on adding this with ur kits ur selling Right? i mean id hate for anyone to mess up there ride on insuf. info
GarrettMoore
05-05-2007 11:29 AM
aetherH3
38
12-13-2006 10:35 PM
HUDYHUE
05-06-2006 12:57 AM
stallioncustoms
01-14-2006 04:42 PM
