h3 key stuck in ignition what can i do?
Old 11-12-2007, 03:28 PM
hummerhonduras's Avatar
Default RE: my h3 dont want shift
ORIGINAL: hummerhonduras
OHHHHHHH HAZARDSLightsTHANKS A LOT SIR
yes the front wiper fuse blow i remplace it the wipers n sunroof are working good
yes i dont have installed 2 bulbs the right headlamp bulb n amber flashers too am going to auto parts to buy this bulbs. i cant remove the key is locked too the is locked in midle of ACC N lock i cant remove the key too where is the brake interlock?
  #32
Old 11-13-2007, 11:33 AM
LittleWhiteHummer's Avatar
shifter cable on transmission, stuck or broken?
  #33
Old 11-13-2007, 12:15 PM
ORIGINAL: LittleWhiteHummer
i remove the boot of shifter i try to shift manual i can shift manual from shifter cable
  #34
Old 11-13-2007, 01:35 PM
So you say the dash says your in P (park).....
Can you push your vehicle forwards or backwards?
  #35
Old 11-13-2007, 01:38 PM
yes i remove the boot of the shifter n the shifter cable i can put the car in drive manual no with shifter manual i can move the levels P TO R.N,D i can only make this with manual direct from the shifter cable i cant with shifter is locked
  #36
Old 11-14-2007, 09:34 AM
bump
  #37
Old 11-14-2007, 11:03 AM
Did you or anybody else replace the rear tail/brake light bulbs with anything, like LEDs???? Do all three rear brake lights work???
  #38
Old 11-14-2007, 11:13 AM
HummerGuy's Avatar
I can't believe this is still going on
Can't you take it to a mechanic or get it towed to one? I'm sure they have them out there.
  #39
Old 11-14-2007, 11:15 AM
No Because i have the car in my garage i have flat bed my truck coming back 2morrow to tow to dealear but i want to try fix in home maybe hehe
all tailights bulbs are good also the 3 stop
  #40
Old 11-15-2007, 06:02 AM
Steve #1's Avatar
It sounds like your shifter issue is a symptom. Your problem is most likely a short or incorrect wiring repair from the front end damage.
Your damaged wiring near the front turn signal is causing problems with your rear turn signals which are also your brake lights...so you have a problem with your brake lights..... so you have a problem with your shift interlock and your ignition lock.
I don't have schematics for the H3 and I don’t have an automatic, so I can’t give you any more help as to where else the short could be.
Quick Reply: h3 key stuck in ignition what can i do?
