h3 key stuck in ignition what can i do?
Hi I HAVE H3 06 key is stuck in ignition i cant remove the key from switch what can i do? what i need check? please help me
RE: my h3 dont want shift
Bogus key locks the shifter. Where did ya get it from???
ORIGINAL: hummerhonduras
[sm=exactly.gif]
hi sorry i have poor english when i push the brake press the bottom on the shifter dont push its hard i cant move the shifter to R TO DRIVE etc etc undestand?
If your key is stuck in the ignition, your shifter is locked.
i cant remove the key is stuck in on the key have 3 or 4 steps i only can move 3 steps i cant back complet the keyback just front start the car everthing good but i cant remove the key is stuck on acc
ANY ONE
i cant remove the key is stuck in on the key have 3 or 4 steps i only can move 3 steps i cant back complet the key back just front start the car everthing good but i cant remove the key is stuck on acc
ORIGINAL: Shellback
Hmm, so you can't turn the key to "lock" position? Are you sure the shifter is on "park"?
the Light N DASH P OF PARKING ?
RIGHT i cant put the key on lock position i cant
the car start i cant drive because the shifter is locked
