H3 front rattle fix
Old 09-29-2009 | 07:44 PM
IndyCar's Avatar
Default H3 front rattle fix
I'm a newbie and sorry if this has been discussed in a prior thread. I have had the "drive you crazy" rattle under acceleration with my 2008 H3. This is not the steering shaft problem that many of you have had.
There is a small skid plate under the transfer case (under the front passenger door) and I found out that if you tap this with your knuckle it will resonate for a good 20 seconds or so almost like a tuning fork. I put some foam backed weather strip in between the skid plate and the cross member and viola, problem solved.
I can't guarantee that this will solve some of your problems but I have driven it for most of the day today and no rattles.
Hope this helps!
Old 10-15-2009 | 02:47 AM
gnatra's Avatar
Default Rattle @ 3000 rpm
I have a 08 H3 adventure with similar problem. intermittent Rattle at about 3000 rpm. you can feel it from inside the vehicle but nothing from the engine bay.
The skid plate might be a possible source. will check it out this weekend.
StormKatMan
06-12-2013 08:29 PM
Hummer2006h3
05-30-2011 03:01 PM
OUTLAW
10-15-2010 03:23 PM
PJ H2 SUT
09-28-2010 02:03 PM
TINKED
05-11-2009 11:40 AM
