H3 front E-Locker retrofit?
Thanks TINKED..., that is pretty much what I'm hearing as well.
My rig does have the cast iron housing so it sounds like the fit should be fine!
From what my local Hummer dealer tells me, there will be a problem with the wiring. Apparently my 2008 H3 Alpha has a different dash wiring harness & Transfer Case Control Module than a 2009 with the Front Locker.
I am thinking that I could bypass the problem by wiring the front locker switch through an axuillary fuse, and then to a lead from the 4x4 Low switch that is hot only when the 4x4 Low is engaged. That should make it fairly idiot proof & that way I should'nt have to worry about the computer spazing out and thowing any funky codes when I lock in the front!
Does that sound like it would work....., or am I over looking something???
I'm what you would call "electronically challenged"..., I don't have much of a clue when it comes to electronics!!
Any info. from anybody will be greatly appreciated!
4u33er
09-10-2012 05:09 PM
SafariHummerH2
05-27-2010 11:47 AM
Mikkofin
02-01-2008 02:01 AM
merkur92
07-20-2007 03:07 PM
