H3 Black Cloth 7" Headrest Tv's + DVD Player
$500 obo need to get rid of asap!!!
This item passed all of the above listed functionality tests with no issues whatsoever. One of the poles has some scratches on it, but nothing major. . Please view the pictures for more details regarding the condition and actual size, shape, and color of the headrest. The DVD Player is a SEPARATE unit from the headrest. It was tested and also found to be in good working condition.
ITEM INCLUDES: Myron & Davis 7" Headrest Monitor - Black, IR Sensor, Wiring Harness, Mounting Brackets (DVD), Power Supply (DVD)
ITEM MISSING: Headphones, Wireless FM Modulator, Remote (DVD), Manual (DVD)
Manufacturer: myrondavis Model: hrm70
HRM-70 Headrest Monitor Specifications: [ul][*]7.0" Active Matrix Display 16:9 Wide Screen[*]Resolution: 1440 x 234[*]400 Nits High Brightness[*]Tilt Headrest for optimal viewing angle[*]30° Pivot Screen[*]Built-in Dual Channel Wireless IR Headphone Transmitter with Stereo Input (2.3MHz/2.8MHz)[*]User Select 7-channel Wireless FM Modulator ON/OFF Switch on Front Panel of Monitor for ANT-129[*]2 Composite Video Inputs 1 VP-p 75 Ohm[*]Viewing Angle: Left/Right: 65 degree,[*]Top: 50 degree, Down: 50 degree[*]NTSC/ PAL Auto Switching Operating System[*]Auto Shut Off[*]Brightness and Color Adjustment Control Buttons[*]IR Sensor Input for DVD Player[*]Monitor Dimensions: 9.5" x 6.3" x 1.3" [/ul] Myron & Davis 3/4 DIN DVD Player - AD212 [ul][*]Small Enough to Fit in the Glove Compartment[*]Mount Any Angle[*]DVD, VCD, SVCD, CD-R, CD-RW, MP3 Compatible[*]Last Scene Memory[*]Slot Type Disc Feeder[*]On Screen Display Menu[*]Full Function Wireless Remote Control[*]Volume Control[*]Zoom Feature[*]Slow Play Back[*]4 Speed Scan[*]Step Play/Program Play[*]Frame By Frame /Slow Motion[*]A/V RCA Input For Video Game/ Camcorder[*]Multiple Language Menu/ Subtitles[*]Multi Angle[*]NTSC/PAL Compatible[*]Mechanical/Electronic/Memory Anti Shock[*]Dimensions: 6.3" x 6.3" x 1.3"[/ul] [hr]Select a picture
smileynialley
09-06-2012 02:21 PM
gregaac
12-14-2011 08:32 PM
SemperSaint
03-10-2011 06:20 PM
