H3 Alpha engine overheat
RE: H3 Alpha engine overheat
Let a bunch of air out of those tires!!!! For sand use 4hi lock, turn off the StabiliTrack. Tires should be less than 20 psi, I run mine at 15 psi.
When you run with street pressure, you are working the engine much harder. Sand also saps power, power makes heat!
Get a little compressor and check it out aired down.................like night and day.
ORIGINAL: fragss
Yesterday I ran the truck on sand for1 minute at full throttle, 5-6k rpm, using the 4low, the engine temperature was on red at full. Is it normal? I checked the coolant level, was ok.
Any ideas?
Thanks in advance
Any ideas?
Thanks in advance
zefrum
03-07-2020 11:03 AM
KingJoseph
03-17-2014 01:42 PM
deejaykaygee1
01-20-2010 05:57 PM
finall
03-13-2008 03:18 AM
brandon4589
11-25-2007 03:25 PM
