H3 2006 overheating, can’t find problem after changing several parts. HELP!
Old 07-10-2019 | 07:21 AM
Cgiraldo's Avatar
Default H3 2006 overheating, can’t find problem after changing several parts. HELP!
I have a hummer h3 that’s been overheating for a while now. Mainly in the summer when the AC is turned on but even with it off on a hot day the gauge goes pass the middle. I’ve changed the thermostat & water pump. What else could it be? Mechanic can’t figure it out, any ideas are appreciated!
Old 07-10-2019 | 08:37 AM
amrg's Avatar
Check this, post #3 is your answer
https://www.hummerforums.com/forum/h...-parked-27380/
Old 07-10-2019 | 11:51 AM
Passed the middle is NOT overheating....... When it is in the red, then that would be overheating. Your "mechanic" is burning your cabbage for nothing.
Old 07-10-2019 | 05:15 PM
I just performed my annual temp gauge check, @ idle in my back yard, enclosed with 6ft wood fence:
Outside Temp: 93degrees
KOEO: coolant temp: 113degrees
Startup: coolant temp: 115degrees
1/4 gauge: coolant temp: 154degrees
Thermostat open: 194degrees (drop to 190degrees)
Center 1/2 gauge indicator: 195degrees
Idle for 1/2hr: 199degrees
AC on for 15minutes: 201degrees
Indicator still points @ halfway mark, just to the upper part( scanner ect is the bottom line @201degrees):
ericksos
09-23-2019 08:14 PM
Hoff
05-29-2018 07:00 PM
blackbeauty
07-30-2013 09:11 PM
H3_4ME
07-09-2012 04:02 PM
DaWgPoUnD
06-29-2012 06:27 PM
