H2's and gas
RE: H2's and gas
[:@][:'(][][:-][&o][X(][>:][8D][&:] 64 more hp and 79 ft/lbs torque [:@][:'(][][:-][&o][X(][>:][8D][&:]
***** www.predatormotorsports.com *****
Raptorq Computer
Buy the Raptorq!!!!
I cant stress it enough.
The programming curves are the best out there. You people will thank me later
________
montana medical marijuana dispensary
Raptorq Computer
Buy the Raptorq!!!!
________
RE: H2's and gas
I have one in every Hummer I own. It is WELL WORTH THE PURCHASE PRICE.
By the looks of the projects I get into and what is done to my trucks it is basically trial and error I go through and end up weeding out junk.
Best computers : Predator Motorsports
Best Headers : JBA Titanium ceramic shorties
Best Plugs : NGK TR6 or TR55
Best Wires : JBA 0855
Best intakes : K&N FIPK with the pre-filter sock on it
Best oil n filters :Amsoil Series 2000 0w30 and AEO filters.
Best Brakes : EBC Green Stuff series 7000 with slotted/drilled rotors by ebc
Best Headlights : BiXenon upgrade by Predator Motorsports
Best Exhaust (flow and sound) - Corsa and Magnaflow (Tie)
Best Supercharger : ATI Procharger.
Best Tires - Nitto Terra Grapplers
Someone should make this into a sticky.
________
easy vape review
________
easy vape review
RE: H2's and gas
I'm just happy my H2 doesn't require 92grade, everything else I own is supercharged or RT so I have to spend the $.20 more per gallon ( *&%^# ).I guess when itcosts$80 - $90 to fill up the Big Baby as it is, what would$.20more even matter...
RE: H2's and gas
How about this... I fill up the tank to its max, when the gas drips out, im done... I start up the H2... I check the range - which im assuming is supposed to estimate how many miles you can travel before running out (am I right?)... it listed 299 miles... I never checked to see exactly how many gallons of gas I actually put in - but I read that it should be a 32 gallon tank... so now im thinking that the actual mpg is more like 9.3, not 11.2... Am i misunderstanding something here? I wondering if the shown average of 11.2 is accurate.
BTW this is the chip i bought off of Ebay: http://cgi.ebay.com/ebaymotors/REAL-...QQcmdZViewItem
And I still ask everyone that drives a H2 - if you live in the city, whats your average mpg? Im trying to see if I should just pull the plug on the chip and leave it OEM, or try something else...
Again, all feedback is much appreciated. Thanks.
RE: H2's and gas
Oh my - those POS resistors have been floating around the net and ebay for years.
They are JUNK
You put it inline with your mass airflow sensor AIR INTAKE TEMPERATURE signal wire. It fools the computer that the air outside is -32 degrees. YOU BURN MORE GAS. ENGINE DETONATES IN HOT WEATHER.
I have a bunch of those things from a company called nextlevelracing.com - its a resistor inside a box with epoxy. THATS IT.
________
d3 platform
They are JUNK
________
d3 platform
RE: H2's and gas
Youre welcome... I put it up for people to see because I did the whole trial and error thing... You can tell because people are buying my parts I am selling on here that I take off
Some stuff may be expensive (like the supercharger or the computer) but is far worth it in the long run... Even the cheapest of parts out do expensive ones. Like the spark plugs - NGK TR6 ($2 ea) compared to NGK TR55IX ($13 ea)...
Wanna really mess up your trucks performance? Yes I said MESS IT UP....
Put in ANY fuel that contains 10% ethanol. Look at the gas pumps - Sunoco does it now, Exxon (some), Mobil... You are putting in a fuel with less energy per gallon (or Liter to you Dwaxman with the ethanol compared to straight gasoline...
To Save fuel - Keep all the tires inflated to 42PSI (Nitrogen in the tires helps), Use a K&N or FREE FLOWING FILTER, a FREE FLOWING EXHAUST, and DONT ROMP ON IT OFF THE START. Simple
________
w212
________
w212
