H2 tire pressure
Old 08-09-2006 | 01:06 PM
Sugardaddy's Avatar
Default H2 tire pressure
I first searched for this topic but to no avail. What tire pressures do you all run in your H2? Up until yesterday, I had mine adjusted to 37psi, which is the recommended pressure on the door panel. On the side of the tire it says 50psi cold. In my very analytically finite mind, LOL, I figured that a higher pressure would decrease rolling resistance and maybe up my MPG slightly. So I set it at 45psi. The problem now is that the dash board rattles and I don't like the ride. I definately preferred the ride at 37psi, but although it's the recommended pressure, is it too low for the real world? Just want some of your thoughts.
Old 08-09-2006 | 03:22 PM
blackstangs281's Avatar
Default RE: H2 tire pressure
Stick with 37 to39. Any higher and you will wear out the inside of your tires after a while........I keep 39 in mine
Old 08-09-2006 | 04:05 PM
Sugardaddy's Avatar
Thanks!
Old 08-09-2006 | 04:22 PM
Sugardaddy's Avatar
Blkstg281. I graduated from Penn Hills in 1983 with a friend of mine with the same name as your's. Wouldn't that be something.
Old 08-09-2006 | 06:07 PM
I graduated from Kitt.......but it's nice to know someone has the same name around here that i could pin stuff on. LOL.
Old 08-09-2006 | 07:36 PM
Sugardaddy's Avatar
There ya go.
psych0
09-16-2010 06:35 AM
HEATHERH2
10-19-2006 03:15 PM
razorbackfan
09-23-2006 12:18 AM
importkiller
09-16-2006 12:46 PM
TIM06H3
02-08-2006 11:00 AM
