H2 solid axle conversion
I've been kind of obsessed with the thought of having a straight axle on the front of the hummer h2. It would be a beast.
As far as I know, the front of the H2 frame is the same as the 2500 frame.
My question is, would I be incorrect in thinking I could use a solid axle conversion kit made for the 2500?
thanks!
thanks!
that's a totally custom setup and atleast 12-15 inches of lift.
My question is about the front of the H2 frame vs the the 2500hd frame.
Just to give you an idea, as you know the H2 shares the same front frame with 2500HD.
Off Road Unlimited Solid Axle Conversion, Convert your IFS to a Solid Axle
All the 2500's Ive looked under look the exact same as the H2, to me. But Im not comparing every hole, and nook and granny. Ill start paying better attention.
I think it would be an awesome project. The kits are around $1500 an then just finding and axle and any mods you want to do to it.
I saw a thread somewhere that said 03+ dodge front axle work with the electronics. Any insight on this?
http://www.hummer4x4offroad.com/foru...-solid-axle-H2
Exactly. I really think it can be done way cheaper than most believe.
Low budget solid axle H2...
So far I haven't found anything really documenting a SAS on a H2.
Maybe you need to be the 1st....................
Theres a 10.5 14 bolt, and Dana 60 for sale local to me...........
Had a funny hair to try this swap, but all the reading I've done its not worth it.
Id like to get the 10.5 14 bolt, but the guy wont separate.
