H2 Heat only works when set at 90 degrees!
Old 01-06-2009, 02:12 PM
danaw's Avatar
Default H2 Heat only works when set at 90 degrees!
Hi All!
My 2003 H2 will only blow heat when set at 90 Deg., not 75 or 80 or even 85, 90 degrees! I recently moved from OH to WA and never experienced this issue in OH where we have very cold winters. The dealer in WA say that this is normal? I have searched the forums without any luck, Please help.
Old 01-06-2009, 02:16 PM
pteam's Avatar
Default RE: H2 Heat only works when set at 90 degrees!
Could be your blend doors. which are a major pain in the *** and will cost like $1000 to replace or if you try to do it yourself its like a 10 hour job or more.
Old 01-06-2009, 03:04 PM
Thunder Cat's Avatar
It may be the same problem I have, it's the blower control module easy to replace cost around $100 bucks
Old 01-29-2012, 12:52 AM
danaw's Avatar
Can you elaborate on this Thunder Cat? I know its been a while, but i still have not fixed it!
Old 01-29-2012, 04:50 PM
accely's Avatar
+1
I had similar problem where it would only blow when the fan was on the highest setting. Replaced the blower control module and it was fixed
Old 11-02-2012, 02:31 PM
GubuH2's Avatar
Originally Posted by accely
+1
Is the Blower Control Module easy to access? Where abouts is it in the engine compartment? Thanks.
Just want to confirm the P/N from ACDelco is # 15-80655 or GM 93803637.
Ben
Old 11-02-2012, 06:26 PM
bflorin's Avatar
Its not in the engine bay, its under the glovebox. Its plugged into the blower motor.
Old 11-04-2012, 01:26 AM
GubuH2's Avatar
Thanks bflorin. I replaced it yesterday and all is good the problem is gone!
Old 11-27-2012, 12:02 AM
danaw's Avatar
Hi TC,
The fan will run at all settings. It blows cold air on settings from 60-89, when you put it on 90 then heat comes out. Still think its the blower module? Thanks
Old 11-27-2012, 12:04 AM
danaw's Avatar
GuguH2,
What was the part number, cost and location of the blower module? How long did it take you? Thanks!
Quick Reply: H2 Heat only works when set at 90 degrees!
