H2 2005 Air Suspension issue
Old 02-13-2017 | 10:48 AM
Jonas Natten's Avatar
Default H2 2005 Air Suspension issue
Hi there, I'm having trouble with a Hummer H2 2005 with air suspension.
Its riding at the bottom, and when i turn the key i can hear the pump doing about 5 cycles, then nothing.
I saw a thread somewhere with the same issue, but no reply that solved it.
Anyone got any idea what i can try to do?
Old 03-10-2017 | 11:26 PM
chrisman04's Avatar
Swap it out for springs. Rear shocks and coils ran me about $500 and another $400 to have installed. You can do them yourself in a couple hours with a little more than basic knowledge.
Old 03-10-2017 | 11:27 PM
chrisman04's Avatar
Strutmasters
Old 03-11-2017 | 10:50 AM
Or you can determine whats wrong and fix the air ride. If the bags are just worn out which is quite likely with the age then you can replace those for much less $$$. If the compressor is shot or other issues then it can get expensive. I know the trend for most is to do the spring swap but I personally like the air ride. The air ride lasted over 10 years, it just needs a little more maintenance is all and does have a better ride and is far superior if you ever use your rig for pulling trailers.
PewterTank
12-09-2019 02:41 PM
Godfather-t
08-27-2015 03:37 PM
Sooner1
11-10-2011 08:58 PM
Sooner1
09-23-2011 07:59 PM
calif phil
02-25-2011 02:00 PM
